Home > For Sale > Complete Turbo Kit, T2, Manifolds, Megasquirt, Plenum
dan187
Member #: 6724
Wootton Bassett
Postage is in addition to the prices below, all in good working condition unless noted otherwise:
12G295 Head unskimmed. Double valve springs. Was used on my 998 turbo before the valve burned away (see photos), Hence why I am splitting the car and engine.
£145
T2 Turbo from Renault 5 (water cooled) with adapter plates mounted on metro manifold and uses T3 exit elbow. Includes oil feed hose and return pipe. Actuator moved to fit mini. Minimal play. Usual crack in the turbine housing.
£275
Turbo carb and inlet manifold. Rebuilt 10,000 miles ago. Needle is for 110bhp 998.
£175 - Carb Sold (manifold available £30)
Metro Plenum modified to allow intercooler fitment and has IAT tapping and sensor (for megasquirt, see below).
£65
Metro fuel regulator.
£35
Maniflow T3 downpipe, modded slightly to fit the T2. Has a couple of dents.
£30
T3 Exhaust clamp (fits the above downpipe)
£15
ITG air filter
£30
Audi/ Saab recirculating dump valve
£7
In-car bleed valve
£10
PlayMini 3" Stainless exhaust backbox and link pipe. Dent in back box
£135
Megasquirt 1 ECU built up without fuel drivers (ignition only, can be completed to make fuelling). Complete electronic igntition system which alters timing for warmup and if IATs get too high (and everything else that MS1 can do, apart from fuel). Includes coilpack and leads, crank sensor, IAT connection (plug on plenum), CLT sensor and heater adapter block to mount it. Toothed pulley and mounting bracket are still on engine but can be included for extra £65.
£365
the 998 bottom end (engine without head or cam)
£60
Edited by dan187 on 27th Jan, 2014.
1275 EFi Turbo
dan187
Member #: 6724
Wootton Bassett
carb sold
Manifold still available £30
1275 EFi Turbo
dan187
Member #: 6724
Wootton Bassett
I'll be at Combe on the TM stand this weekend. If anyone wants to make offers on the above let me know. I'll try and bring most bits along.
1275 EFi Turbo
thejefinabox
Member #: 9597
I may be interested in the 998 bottom end, could you pm me some details of it please? Ta
dan187
Member #: 6724
Wootton Bassett
I've not had chance to sort out selling this recently but I'll be putting this up on eBay in the next week so any takers before-hand, get the messages in now.
1275 EFi Turbo
BenAnscomb
Member #: 10739
Hello mate, what have you got left for sale?
dan187
Member #: 6724
Wootton Bassett
Hiya mate, all the bits with a price are still available.
1275 EFi Turbo
BenAnscomb
Member #: 10739
What's the lowest you would take for the head?
dan187
Member #: 6724
Wootton Bassett
Where are you located? Will i have to post it or can you pick it up? What's the highest you'll offer?
1275 EFi Turbo
BenAnscomb
Member #: 10739
I'm in clacton Essex so it would have to be posted mate. What sort of price would I be looking at for new valves as it has burnt away? Sorry for all the questions and not much knowledge, as you can probably presume I'm new to this sort of thing
dan187
Member #: 6724
Wootton Bassett
Valves are less than £20 each but you'd want a machine shop to seat it properly. The best bet would be to give Benross a PM and get him to open it out and fit bigger valves. You'd be able to get circa 150 bhp from it then.
1275 EFi Turbo
BenAnscomb
Member #: 10739
How much would you take for it mate?
