Home > Technical Chat > Plotting compressor map for restricted car
jakejakejake1
Member #: 10010
Northants
Hi Everyone,
Was wondering if anyone could help me out with plotting some operating lines on a compressor map, the car we are dealing with has an inlet restrictor before the compressor which causes things to go a bit funny.
I understand once you reach the choke limit of the engine the air mass flow rate won't increase, and as the mass flow rate goes up the inlet pressure before the compressor will go down, and thus a higher pressure ratio will be needed, I think.
Has anyone got an examples of a compressor map with a line of this type plotted on it for reference?
If it helps, its a 600cc engine revving from about 3-4k up to 11-12k, 20mm or 19mm restrictor (depending on petrol or E85 respectively), looking at using a GT12
(map: www.turbomaster.info/img/aplicaciones/GT1241-756068-0001-compmap.jpg)
Jake
This might be a good forum to ask
http://efi101.com/forum/viewforum.php?f=10
But I think monitoring impeller speed is a better way of optimising performance when restrictors are involved
The restrictor reduces the inducer pressure, thus increasing the pressure ratio, and therby reducing the effective mass flow of the compressor. Basically as the mass flow increases towards the maximum mass flow that the particular restrictor can achieve, the pressure drop across it also increases. Since the higher pressure available is atmospheric pressure, the compressor inducer pressure is actualy in a vacuum. The compressor map works pretty much the same way as it does without the restrictor, but the pressure ratio usually noted on the Y axis will increase with the lowering inducer pressure as mass flow increases and sustained exducer pressure.
The key is the restrictor. Work out the mass flow and pressure drop of the restrictor, work out that pressure ratio from that, then you should be able to plot that on any compressor map
But restricting it also causes the impeller to spin much faster, and I think that's where the risks lie. Overspinning the unit.
The published compressor maps are based on atmospheric inlet pressure and temperature (i.e. density) at the inducer. Hence the pressure loss through the restrictor will reduce the density of the air entering the inducer.
So to adjust the map to take into account of the restrictor you need to correct the inlet conditions. Roughly speaking, if you create a 0.5 Bara condition at the inducer inlet, you will need to halve the X axis of the map.
The Y axis will be unchanged but, of course, the inlet pressure has changed so the outlet pressure will also change, but the pressure ratio will stay the same.
There is a point at which the inlet pressure will no longer supply enough air and the compressor inducer will fail on suction performance.
dan187
Member #: 6724
Wootton Bassett
Sounds like someone is working on a formula student car! how's it going?
1275 EFi Turbo
jakejakejake1
Member #: 10010
Northants
Yup, you guessed it. We are not too far along, and are not looking at running until 2015, I'm just doing some preliminary investigation into the feasibility of charging the engine.
The funny thing is that charging the engine doesn't actually result in more power, but you use it instead to maximise use of the restrictor and create a nice flat power curve.
Think I will have to run some simulations to get a proper compressor inlet numbers to plug in.
Also, any ideas for super chargers, had a look at a couple of Rotrax chargers (C8 and C15), but I'm wondering if there are any options available.
And as for turbos, I have been looking into GT12, GT15 and GT15V. An Australian team has got the GT15V running really well, 100Nm torque at around 3000 rpm I think (typical engines run about half of this!). They have also said they have managed not to melt it yet despite their best attempts running anti-lag etc.
I personally quite like the idea of a 450 single running a turbo, but will have to wait and see what the numbers say.
sounds interesting, going a bit off topic, where do you buy your e85 from?
jakejakejake1
Member #: 10010
Northants
Good question, we have never run it in the past as it means you need a smaller restrictor and results in less power when NA, but when boosting the knock resistance makes it worth it. At the events its supplied by Shell I believe, so I guess it would be a case of speaking to them. And I'm guessing it will come in drums rather than out of a pump.
As for Paul's scaling of the X axis, would this actually need to be done? As the garrett maps have air mass flow rate, hence density/ temperature/ velocity is already taken into account? I understand that would be the case for the maps that have a volumetric flow rate.
Or is it a mass flow rate calculated from atmospheric conditions?
Jake
Given the drive losses with a supercharger, dont think it would even be worth looking at compared to a turbocharger.
Unless it allows you a larger restrictor or something
jakejakejake1
Member #: 10010
Northants
I understand in power terms its inferior due to more losses, but in terms of drivability it would be better.
The courses are very winding, and you don't get much/any practise before they expect you to drive it, so having good throttle response and drivability are key.
You've answered your own question. The mass flow is calculated from a volumetric flow at a given specific volume at atmospheric conditions. Compressor performance is all about the speed and cross sectional area of the passages i.e volumetric flow.
I guess you need to determine exactly what your usage criteria are. Is it outright power, torque, economy, etc etc ? What sort of rpm range will you have, what gearing options ?
With such a small restrictor, I'd think if you can find a turbo small enough, spool wouldnt be a major concern and you could make boost very early anyway. So is the supercharger really a benefit ?
Maybe even opt for a modern VNT turbo
Also, what cost limitations are there ?
