Home > Help Needed / General Tech Chat > Mpi block oil return?
Will
Member #: 11091
As the casting of the block doesnt have a mechanical fuel pump what do people use?
I gather tap & dying into where the camshaft sensor goes?
Or return it through the gearbox casing just below the engine flange.
Gomme
Member #: 10528
Denmark
I put mine in the gearbox, just below the engine flange.
dan187
Member #: 6724
Wootton Bassett
I haven't got round to fitting the turbo on mine yet but drilled holes when building the engine so that I could copy this idea...
1275 EFi Turbo
Will
Member #: 11091
Looks good and probably the easiest to do
not sure whether to go for the snap on fittings or tap something like this into the plate on the gearbox
just abit concerned about creating another place for oil to leak from haha
Edited by Will on 18th Mar, 2015.
Will
Member #: 11091
5/8 tail should do the job?
or 3/4?
