| Home > Help Needed / General Tech Chat > re: 5/16 unf gearbox to engine bolts | |||||||
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
3rd Nov, 2005 at 09:23:51am
Just a little query before i start sorting out my machining to be done on my engine. Is it worth it? The engine will be a N/A 16v with the bimma head, but no idea on the power i am looking at, but the engine may get supercharged later on if i have the time/inclination! |
3rd Nov, 2005 at 09:42:56am
I haven't bothered on my engine, as I won't be revving it much past 6500rpm.
3rd Nov, 2005 at 09:43:26am
I've done it on many cars, but not on my turbo. It doesn't leak though. There are some copper gaskets to be bought now which are supposed to eliminate this.
3rd Nov, 2005 at 04:59:03pm
That was my thought, at least then my options are open for the Supercharger etc. Now lookin into 4 bolt mains for it. Getting the crank done to the best possible spec on a CAM 6232. So hoping to be able to rev to 7000-7500. Probably set the limiter to 7500. The cams haven't got a huge amount above that so rather have a little bit more reliability/ more time between rebuilds. |
6th Nov, 2005 at 10:28:56pm
Bolts not a problem when you work for a Race team!!! All the stuff i work with has imperial stuff on, if i am lucky we may have a few nas bolts kicking around to use in it!!
7th Nov, 2005 at 08:44:34am
or you could just use the normal standard ones that are fine to use! been using then for years. Best 1/4 mile 13.2 seconds @116 mph
20th Dec, 2005 at 10:11:56am
Dave, I seem to remeber that you had some thoughts on this... Cannot find them (your thoughts) now.. Share, please Edited by Vegard on 20th Dec, 2005. On 13th Jul, 2012 Ben H said:
