| Home > General Chat > Reaming rods for floating pins | |||||||
6th Sep, 2007 at 01:28:51pm
I want to convert my S rods to run floating pins. Can anyone advise a good place to get this work done and what sort of price to pay?
6th Sep, 2007 at 01:45:13pm
I seem to remember a topic on this before, I think Mr Austin offered his services. On 28th Aug, 2011 Kean said:
6th Sep, 2007 at 01:47:42pm
Yeah ive seen a couple of posts on it but don't recall any companies mentioned? Hmm, I'll have another look. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
6th Sep, 2007 at 02:07:34pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=133878
7th Sep, 2007 at 01:06:32pm
Just had a look at my rods and they might be reamed already. :)
7th Sep, 2007 at 01:56:32pm
the pin i have here comes out at 811-812 thou, but thats using verniers. On 28th Aug, 2011 Kean said:
7th Sep, 2007 at 05:23:23pm
Do you have a measurement for a standard gudgeon pin? The only pins I have are still fitted to pistons.
8th Sep, 2007 at 03:30:27pm
the 811-812 was for a std one from an S rod.
8th Sep, 2007 at 05:58:21pm
Im completely confused now!! As far as ive read rods need to be reamed to fit floating pins. Ive had a look on MED's website and it doesn't mention anything about reaming, if anything they mention supplying a bush to reduce the size of the little end to 18mm to suit the gudgeon pin??
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
8th Sep, 2007 at 06:03:56pm
How are the gudgeon pins fitted to the pistons on the cooper s rods? Edited by Jordan on 8th Sep, 2007. Back once again like a renegade master |
8th Sep, 2007 at 06:07:33pm
Ahh,
8th Sep, 2007 at 06:14:48pm
I measured the bore in the rods and it was 20.64mm to 20.68mm between all four rods. Only had a vernier, so not the most accurate measuring equipment.
Edited by matty on 8th Sep, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
8th Sep, 2007 at 06:28:09pm
Sounds like it but this might just make sure that it goes in with no seizures (like on vlave guides).
8th Sep, 2007 at 08:08:30pm
Gudgeon pins are all the same diameter for the 1275. Hone the rod little end for a clearance on the pin, thats all thats needed
Edited by Sprocket on 8th Sep, 2007. On 26th Oct, 2004 TurboDave16v said:
