| Home > Beginners Tech > Metro dizzy wiring | |||||||
13 Posts Member #: 9114 Member Warrington, Cheshire |
7th Oct, 2010 at 06:28:49pm
This has probably been asked before, but I can't find an answer by searching. I need to know what wire goes where on the metro dizzy. It's a 3 pin style connector, but with only 2 pins present in the module. I don't have the metro loom, so I need to know which pin is the positive feed, and which pin is the switched side of the coil. I have a random 3 pin connector which fits, so I need to know which is which wire.
7th Oct, 2010 at 06:34:36pm
these two will provide the answer if you read them both fully
7th Oct, 2010 at 06:46:56pm
Thanks, I already read both those posts, but they only say which pin is which for a 2 pin module. Maybe it's just me being thick..... |
7th Oct, 2010 at 07:11:32pm
Read the last post by Nick in the fist post for what colour wire goes where.
7th Oct, 2010 at 07:18:14pm
I don't have the metro wiring, so the wire colours mean nothing. I need to know if the positive supply is the middle pin or the outer pin (one of the outer pins is 'missing').
7th Oct, 2010 at 07:39:00pm
Yes, I probably have.
13th Oct, 2010 at 10:09:44am
The module you are refering to if memory serves is the later type fitted to the metro sport and the 1.3 GTA
Own the day
15th Oct, 2010 at 06:56:14pm
OK, I got a new module off ebay for £10, and eventually worked out how to wire it up. I now get a spark when I crank the engine. Thanks for the help.
15th Oct, 2010 at 07:25:53pm
![]() 384 Posts Member #: 4215 Senior Member |
26th Oct, 2010 at 11:59:55pm
quick question... does anyone have a pic or diagram of what spark plug leads go where? like what position on the dizzy cap to what spark plug... i think mine are mixed up, as i get a bang on start up.. |
![]() 558 Posts Member #: 8143 Post Whore London |
27th Oct, 2010 at 12:15:31am
Firing order is 1-3-4-2 going anticlockwise on the Dizzy cap, 1 should be the top rightish |
27th Oct, 2010 at 05:32:36pm
stupid question, but how do i know where the top is? is it where the vac advance thing is? |
27th Oct, 2010 at 05:33:09pm
diagram would be awsome... |
27th Oct, 2010 at 07:27:25pm
stood looking at the dizzy the top right is where the 2 hour would be on the a clock Yes i moved to the darkside |
27th Oct, 2010 at 07:31:15pm
remember this is in theory, i have moved the dizzy drive around 180degreese before to stop the vac unit from hitting the oil filter pipe
Edited by Brett on 27th Oct, 2010. Yes i moved to the darkside |
27th Oct, 2010 at 08:26:55pm
thats perfect mate... thanks a lot buddy |
28th Oct, 2010 at 12:07:03am
another stupid question... are the spark plugs numbered 1,2,3,4 from left to right, or right to left?
28th Oct, 2010 at 07:57:11am
number 1 is next to the water pump.
28th Oct, 2010 at 02:49:10pm
ok thanks mate |
