Home > Help Needed / General Tech Chat > IAT and CLT Sensors
dan187
Member #: 6724
Wootton Bassett
I've had a search but can't find my answers (did find one amusing thread about flogging stuff for more that it's worth).
I'm after an Inlet Air Temp sensor and a Coolant sensor that I can plug into Megasquirt. You can buy them off efiextra for about £17 each but I'm just wondering what cars people have taken them off of at a scrappy? And how much effort recalibrating sensors in MS1/extra is?
1275 EFi Turbo
Coolant ones are easy, just grab one that loos right an calibrate to suit,
IAT ones you need a faster reacting type than the water one, I use the green rover one.
calibration wise you need to enter three values for each sensor, 0 deg, 20deg, and 100 deg, some sensiors you can find a datasheet for, some you'll need to measure, which is pretty easy
http://cgi.ebay.co.uk/LAND-ROVER-DEFENDER-...=item3a62fa97d6
http://cgi.ebay.co.uk/ROVER-K-SERIES-INLET...=item588b885d5a
dan187
Member #: 6724
Wootton Bassett
Great thanks, I'll get to a scrappy soon and have a look.
Where have you placed the IAT? I was going to fit it in my plenum.
1275 EFi Turbo
mines in the plenum but it heat soaks fairly badly, I'l considereing sticking it in the hose before the tb
I use the Cossie ones,
Cheap of eBay new (non genuine but OK) and their calibration tables are readily available.
Bosch ones are also reasonably cheap and the calibration tables are published by Bosch.
If you have the figures, whatever you use, Megasquirt only requires three points on the curve to calibrate.
Was just scratching my head trying to work out why you wanted a clit sensor...
The clit is the sensor
turbominivanman
Member #: 1504
Westbury, Wiltshire
Try this Dan.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=219955
You'll find I posted the resistance curves for the Rover SPI/MPi Green AIT and Rover MPi Brown CLT sensors.
I'm using both with Megasquirt and MS1/Extra.
No probs getting the temp sensor cals into the MS code.
Richard.
dan187
Member #: 6724
Wootton Bassett
Great, thanks chaps
1275 EFi Turbo
