| Home > Help Needed / General Tech Chat > Turbo build shopping list | |||||||
8 Posts Member #: 9467 Junior Member Gloucester |
16th May, 2011 at 12:33:19pm
Hi all,
Edited by Cruster on 16th May, 2011. |
16th May, 2011 at 12:58:37pm
looks like your on the right track,
Yes i moved to the darkside |
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
16th May, 2011 at 01:09:10pm
if you're dropping the compression ratio from standard (what's that about 9.4:1?) down to 8.25:1 won't you lose low to mid-range torque?
16th May, 2011 at 01:21:23pm
8.25:1 is pretty low too. If something is worth doing, it's worth doing half of. |
16th May, 2011 at 01:25:28pm
depeding on the boost you desire, and for road use/track use, i would go for about 8.5:1, i feel this is perfect, still gives good mid range pull, but the capability to run 16-18psi PROVIDING fueling and timing are spot on. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
16th May, 2011 at 01:31:39pm
You should also think about an intercooler:
On 26th Nov, 2005 BENROSS said:
remember the intercooler is not the icing on the cake its MORE cake On 11th Feb, 2015 robert said:
16th May, 2011 at 01:40:08pm
I like cake! If something is worth doing, it's worth doing half of. |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
16th May, 2011 at 01:43:14pm
i also wouldnt be starting with a metro turbo engine unless youve already got it.... a lot of money to spend for no benefit"!! And on the 7th day........... God created turbochargers! |
181 Posts Member #: 9072 Advanced Member Jersey, Channel Islands |
16th May, 2011 at 05:56:56pm
On 16th May, 2011 bennyy said:
depeding on the boost you desire, and for road use/track use, i would go for about 8.5:1, i feel this is perfect, still gives good mid range pull, but the capability to run 16-18psi PROVIDING fueling and timing are spot on. When you say "PROVIDING fueling and timing are spot on", what can you do to ensure this? With the timing, I was going for standard setup but now considering getting a vernier duplex timing kit to get the mechanical timing spot on and possibly megajolt. Would this be good for 16-18psi? What can you do fuel wise? I would have SPI pump and replace the fuel lines with 8mm but looking at upgrading to MPI fuel pump. Do I need to do anything else like upgrade the jets? Sorry to hijack but thought now is as good as time as any to ask. Speed doesn't kill, suddenly becoming stationary, now that's what'll get ya! |
16th May, 2011 at 06:02:25pm
too much advance can run a turbo lump into det very easily which is a big problem, the same with lean air/fuel mixtures, most people on here set timing at around 24/25 degrees and your looking at afr's of about 12:1 at WOT Audi s4 b5 - 470bhp & 486ft lbs
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
16th May, 2011 at 06:33:34pm
If you want to keep a close eye on you ig timing and afr, in my book the megajolt system and an afr gauge are 2 that would be added to your shopping list, they are not totally essential but I would say must haves especially for decent boost levels. Megajolt has been covered many times and IMO is pretty affordable. As for afr gauges most people use the ugeo wideband, again this is covered many times, gives a constant readout of your fuelling, I believe Richard at mirage will send you an exhuast outlet which has the required boss already on it, thats half the battle won, you could use a cheaper narrow band gauge not as good as wideband but as wil-h once said "better than nothing"
depeding on the boost you desire, and for road use/track use, i would go for about 8.5:1, i feel this is perfect, still gives good mid range pull, but the capability to run 16-18psi PROVIDING fueling and timing are spot on. When you say "PROVIDING fueling and timing are spot on", what can you do to ensure this? With the timing, I was going for standard setup but now considering getting a vernier duplex timing kit to get the mechanical timing spot on and possibly megajolt. Would this be good for 16-18psi? What can you do fuel wise? I would have SPI pump and replace the fuel lines with 8mm but looking at upgrading to MPI fuel pump. Do I need to do anything else like upgrade the jets? Sorry to hijack but thought now is as good as time as any to ask. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
16th May, 2011 at 07:16:24pm
Thanks all for the replies. :)
16th May, 2011 at 07:46:31pm
No need to remote mount the turbo to fit an ic, simply pipes between the turbo outlet and carb inlet,, many on here have a mirage setup, decent ic and fit it all in a roundnose mini, If you havent already - www.turbo-mini.com is very helpful, also the search on here is very good all for research.
On 16th May, 2011 Cruster said:
Thanks all for the replies. :) Minor correction.... I meant Jonspeed near Birmingham not Janspeed (doh) Has anyone had an engine rebuilt by them? (Jonspeed) Yes I guess 8.25:1 is a bit on the lowish side. I was basing that on Richard at Mirage's suggestion as it would allow for some additional boost, I understand the stock Turbo Metro runs a bit close to detonation. Someone mentioned adding an intercooler, but I'm not certain how that would fit if I used Mirages kit (which is my current plan) I'm guessing the Turbo would have to be be remotely mounted? I've been looking (ok, lusting after) some nice examples here: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=371975 Are there drawbacks doing this, mounting the Turbo remotely and using an intercooler? I'm guessing perhaps lag is made a little worse? But less inlet heat must help considerably? Talking out loud, I wonder if there are any engineering firms who'd undertake the necessary fabrication of the required plumbing and if so, what the costs involved might be... maybe another route to look at....?
16th May, 2011 at 09:25:51pm
i would steer clear of jonspeed, heard a few bad reveiws
16th May, 2011 at 11:10:00pm
just to point out, my cr is 8.1:1 and i have a Close ratio box with a 2.9FD and its a bastard to get going. need boost to get a good start. |
1300 Posts Member #: 829 Post Whore essex |
17th May, 2011 at 02:55:24am
i bet you love a hill start then 1293 Turbo mini
17th May, 2011 at 11:27:36am
That's interesting advice about (not) lowering the compression ratio, sounds to me like it's not the way to go... thanks for the warning! The plenum mod for the intercooler sounds very interesting, I'll see if I can find that here. (Edit: found and pm sent - thanks for that!) Cheers all Edited by Cruster on 17th May, 2011. |
18th May, 2011 at 06:30:47am
Have a look if you haven't already: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6&fr=0 Isambard Kingdom Brunel said:
18th May, 2011 at 10:11:13am
On 18th May, 2011 Rob H said:
Have a look if you haven't already: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6&fr=0 I hadn't spotted that, many thanks for the link. |
