| Home > Help Needed / General Tech Chat > Over-steer on my mini | |||||||
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
25th Aug, 2011 at 08:44:35am
I've been driving my mini on my hour commute to work and am starting to pick out all sorts of problems with it now.
Edited by dan187 on 25th Aug, 2011. |
![]() 163 Posts Member #: 9181 Advanced Member Rhoose, Cardiff |
25th Aug, 2011 at 09:27:11am
I had this same problem with my 12x6 wheels. This year i span out on a motorway slip road in France on the way to the imm and ended up facing oncoming traffic. Bit of a brown trouser moment!
My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0 |
25th Aug, 2011 at 09:37:46am
see now i get the opposite, I have lots of warning. It feels like there is loads of sidewall give and so i get a spongy back end feel that tells me when i'm pushing it too far. |
25th Aug, 2011 at 09:42:40am
6x12s are by far the best handling combination I have ever had on a road mini. 30mm spacers seems a lot. I generally run 5mm more on the rear, which really helps with oversteer and stability.
25th Aug, 2011 at 09:44:41am
i don't know then. maybe try a bit of negative camber on the back My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0 |
25th Aug, 2011 at 10:16:04am
On 25th Aug, 2011 wil_h said:
6x12s are by far the best handling combination I have ever had on a road mini. 30mm spacers seems a lot. I generally run 5mm more on the rear, which really helps with oversteer and stability. anyway, I would try the following: 1) check that the front is not sat on the bumpstops, and is at least 5mm clear. 2) that the cornerweights are set evenly. 3) that the rear toe is equal and in. Do you find that you need very little steering input? Thanks for reply Wil, I'll have a look at point 1) asap. The 30mm spacer was purely for aesthetics to make the wheels fit the arches nicely. I'll take a bit out. Yeah, very little steering provides more than enough for most corners. corner weights and rear toe however I could do with some help on... With the standard brackets etc, is there much i can do to change the rear geometry? I can shim to give more toe out but can't gain toe in? What brand brackets are best to allow changes? I'm looking at getting minispares MS73 to allow full changes. Might it be that the subframe is mounted on the piss? Will having adjustable toe and camber irradicate the problems of the subframe being wonkey? I live near Somerford Minis, so i could take it to them but i don't want to end up paying lots for them to just tell what geometry feature is wrong but then not be able to adjust it to make it correct. Edited by dan187 on 25th Aug, 2011. |
25th Aug, 2011 at 10:40:42am
Other than corner weights you can get a rough idea with string and a ruler.
1050 Posts Member #: 764 Post Whore Staffordshire |
25th Aug, 2011 at 11:06:24am
i had a similar issue... with the rear of the estate. Found to be toe-in on one side and toe-out the other. |
100 Posts Member #: 745 Advanced Member Northampton |
26th Aug, 2011 at 08:19:23am
probably a toe issue on the back - one side will be 'in', one side 'out'.... |
26th Aug, 2011 at 09:23:07am
I assume you've checked there is no play in the radius arms? I've seen some horendously worn arms in the past that have caused this.
26th Aug, 2011 at 09:43:09am
Thanks chaps.
26th Aug, 2011 at 10:15:32am
How rigid was it, was it moving through its arc as it should? A seized radius arm basically gives solid rear suspension which isn't good for handling.
26th Aug, 2011 at 10:20:21am
Looking at previous posts i've opted for the following settings. It will be used as a road going track and hill climb car (currently my daily drive).
Edited by dan187 on 26th Aug, 2011. |
26th Aug, 2011 at 10:22:04am
Much more front negative camber required.
26th Aug, 2011 at 10:23:11am
On 26th Aug, 2011 Tom Fenton said:
How rigid was it, was it moving through its arc as it should? A seized radius arm basically gives solid rear suspension which isn't good for handling. Thanks Tom About a month ago they were both seized. Fixed that and now they pivot lovely. I meant there is no play in planes where it shouldn't be. |
26th Aug, 2011 at 10:24:11am
Much more front negative camber required. Can I adjust that without buying new arms? Do you say that because of my intended use or other reasons? |
26th Aug, 2011 at 10:26:22am
You will need other arms. 1 deg neg isn't enough in general for a hard driven Mini. Aim for 2 degrees or 2.5 deg
26th Aug, 2011 at 10:41:30am
I disagree with Tom. -1 will be enough IMO, 1.5 a maximum.
26th Aug, 2011 at 10:43:11am
I run around -1.5 from my tracking report, and that's just from the car being lower, i find it about spot on :) On 26th Jan, 2012 Tom Fenton said:
26th Aug, 2011 at 10:51:24am
Thanks for all your inputs guys...
29th Aug, 2011 at 09:31:15am
On my race Mini running 6X12 or 7X12 with 48Rs I use approx 2 neg at the front and very little toe out. At the rear Approx 1,5deg neg and 5mm toe out. I'd guess if you set the rears parallel it'll make a very stable ride. Toe settings are MUCH more important than the camber. On 13th Jul, 2012 Ben H said:
29th Aug, 2011 at 02:28:21pm
5mm toe out at the rear, truly bonkers.
On 29th Aug, 2011 Vegard said:
On my race Mini running 6X12 or 7X12 with 48Rs I use approx 2 neg at the front and very little toe out. At the rear Approx 1,5deg neg and 5mm toe out. I'd guess if you set the rears parallel it'll make a very stable ride. Toe settings are MUCH more important than the camber. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
29th Aug, 2011 at 02:43:03pm
30th Aug, 2011 at 10:42:36am
All set up now and runs much better. Feels like a mini and sticks to the corners. Rather than making me crap myself because i can feel the back end coming round.
Edited by dan187 on 30th Aug, 2011. |
30th Aug, 2011 at 10:54:34am
Good news, and more proof that the 10", 12", 13" argument is not about the size, buit the way you use it. http://www.twin-turbo.co.uk
