| Home > Help Needed / General Tech Chat > Spax or Koni or ???? | |||||||
10th Mar, 2006 at 07:01:44pm
I'm investing in a new set of shock absorbers.
10th Mar, 2006 at 07:40:50pm
everyone has their own opinions, i ended up using spax and cant say anything against them |
10th Mar, 2006 at 08:10:07pm
spax on mine aswell, do the job just fine. On 20th Oct, 2015 Tom Fenton said:
10th Mar, 2006 at 08:25:19pm
Edited by Bat on 10th Mar, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
10th Mar, 2006 at 08:57:03pm
i used gaz and cant say anything against them either I've seen the future and tbh its Pie
1300 Posts Member #: 829 Post Whore essex |
10th Mar, 2006 at 10:46:47pm
i used gaz and spax cant say anything against them it`s up to you 1293 Turbo mini
11th Mar, 2006 at 08:25:26am
Konis aren't really adjustables in the commonly used sense, as in there isn't a knob to adjust its stiffness. All the adjustment is to allow compensation for wear.
11th Mar, 2006 at 11:40:23am
gaz, bilstein and spax are all good, tbh, i cant tell the difference once they were on, guess gaz would be the best as there lightest and apparently rebuildable...? "Turbo's make torque, and torque makes fun"
11th Mar, 2006 at 11:47:19am
I have found in the past they all do the job. A comment I would have is that Spax tend to be on the harder side of things, whereas Konis tend to be softer. This is from experience on both Minis and other cars as well.
11th Mar, 2006 at 12:02:40pm
Thanks for your help.
4th Apr, 2014 at 07:19:34pm
Following a search I've dug this up..
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
5th Apr, 2014 at 03:15:57pm
I've just replaced my rubber donuts after first thinking it was the shocks at fault. It has made the world of difference. Such a good ride now. Bought the minispares standard donuts. The best £180 i've spent on the mini. |
5th Apr, 2014 at 03:21:45pm
All steel shockers on your nice blingy alu shocker brackets??
5th Apr, 2014 at 03:37:49pm
Umm I never thought of that - you make a good point! been looking at protech but wasn't sure on ride quality, don't want it too harsh on the road. |
5th Apr, 2014 at 04:44:29pm
They're adjustable, so you can make them ride as you need. Never heard bad things about them. On 11th Feb, 2015 robert said:
5th Apr, 2014 at 04:46:32pm
Protec is the same guy who was spax, then GAZ. A decent choice. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
5th Apr, 2014 at 08:34:46pm
i'm running Gaz shocks with no issues on old dounuts.
5th Apr, 2014 at 09:12:10pm
Yeah but I thought the Gaz shocks were too harsh for road use so want something softer.. Mind you the last mini did have a weld in cage that stiffened things up considerably.
5th Apr, 2014 at 09:52:22pm
Got a welded in 6 point cage, Gaz shocks and red dot cones this time.
On 5th Apr, 2014 MarkGTT said:
Yeah but I thought the Gaz shocks were too harsh for road use so want something softer.. Mind you the last mini did have a weld in cage that stiffened things up considerably. Think I will try the protechs What the mind can conceive the mini can achieve
